Disables restricted role on the specified port inside the core network.
stpd_name | Specifies an STPD name on the switch. |
port_list | Specifies one or more ports or slots and ports. |
N/A.
The restricted role is disabled by default. If set, it can cause a lack of spanning tree connectivity. A network administrator enables the restricted role to prevent bridges external to a core region of the network from influencing the spanning tree active topology, possibly because those bridges are not under the full control of the administrator.
Disabling Restricted Role at CIST is inherited by all MSTI.
The following command disables restricted role for s1 on port 6:3:
configure stpd s1 ports restricted-role disable 6:3
This command was added to RSTP in ExtremeXOS 11.6 and 12.0.3.
